Alam560
Wiek: 23 Dołączyła: 11 Sty 2026 Posty: 4 Skąd: usa
Wysłany: 11-01-26, 09:39 U4GM Guide Ashes of the Damned Bobbleheads Deathclaw
Waiting for the boss to show up the "normal" way is a slog, and it's why I lean on the bobblehead route whenever I'm chasing that Irradiated Deathclaw Calling Card on Ashes of the Damned. If you're the kind of player who'd rather lock the reward in and move on, you'll probably get why people look at stuff like CoD BO7 Boosting for time-saving help too, because hours of looping rounds isn't exactly the fun part. The good news is the quest is straightforward once you've got a clean path in your head, and it pulls the Deathclaw forward way earlier than Round 50.
Bobbleheads 1 to 3: Quick wins
1) Spawn is your freebie: check the vending machine right away and grab the first Vault Boy before you even start overthinking it. 2) Drop into the Bard Area next; it's dim down there, so slow down for two seconds and scan the chairs instead of sprinting past them. 3) Then go to the Vandorn House, and yeah, you really do need to crouch—look under the dining table like you're checking for a dropped key, not a collectible, and you'll spot it.
Bobbleheads 4 to 7: Ashwood hassles
4) In Ashwood, one is inside the Klaus Cage, which feels like a wink to anyone who's played a lot of Zombies over the years. 5) The next one is the annoying movement check near the zipline: you've got to hit a wall jump to land the ledge, and it can take a few tries if your timing's off, so don't beat yourself up. 6) After that, swing through Exit 115 Gas Station near the Armor buy for an easy pickup. 7) Then grab the one near the LMG at the Exfil site—do it sooner rather than later, because once the map ramps up, that area turns into a mess fast.
Bobbleheads 8 to 10 and the safe kill
8) For the next one, get up onto the raised platforms under the big rocket and you'll see it. 9) Head to Blackwater Lake and snag the one outside the kitchen. 10) The last is at the fishing dock, and once you've got it, watch for the huge Vault Boy hologram lighting up the pyramid structure—that's the "okay, he's coming" signal. The Deathclaw doesn't jog, he launches at you, so don't do the heroic on-foot duel unless you're stacked. Open Pack-a-Punch, call in the Old Tessie truck, and play it smart: run him over, keep moving, and burn him down with the laser. If you want extra breathing room, traps help, and Ted Tasks can make cooldowns nicer, but the truck is the cleanest way to turn a scary spawn into a quick, controlled kill—especially if you're also grabbing gear or services from U4GM CoD BO7 Boosting for sale to keep your runs smooth. |
